Timing? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-30-2004, 01:04 PM
bowtie400's Avatar
Timing?
I HAVE A 400 SMALL BLOCK BORED 40 OVER,.470 LIFT 224 DURATION COM. MAGNUM CAM ,350 RODS, VORTEC HEADS,EDELBROCK RPM PERFORMER INTAKE AND A 670 CFM HOLLEY STREET AVENGER CARB. The motor has good power but it has a hesitation when you hit the gas hard. I thought it might be getting to much fuel at one time when the secondaries opened, I changed the spring to delay the secondaries, it helped a little but its still there. The timing is set at 12 degrees at idle. It has a vacuum advanced hei, I tried connecting to manifold vacuum. What else can I try.
Old 08-01-2004, 02:46 PM
tirefryin_s10's Avatar
Last journal entry: 58
set your total timing that motor should like between 30-35 degrees total timing all in before 3000rpm so try that and see if it helps any
