Timing 454 Chevy BB - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2009, 02:17 AM
Timing 454 Chevy BB
I am installing a new distributor in my 454 Chevy BB and I am not sure of the correct procedure to time it. I think I have all the plug leads in the right order but I'm not sure just where to sit the distributor body or the rotor. The vacuum unit seems to foul the manifold so there aren't many places for it to go.
Old 01-30-2009, 04:34 PM
Place cylinder number one at TDC on the compression stroke, using the timing pointer to guide you exactly where tdc is, then drop the distributor in the hole, with the rotor pointing to where the #1 spark plug tower is. May have to make you a mark on the distibutor where that tower is at with the cap on, then take the cap off and then point the rotor to that mark and drop it in. That will get you close but you will have to adjust the timing a little bit after that.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Chevy 454 overheating no matter what I do rakundig Engine 26 02-13-2011 05:03 PM
Chevy 5.7 Vortec timing fosterdl Engine 1 01-12-2008 08:42 PM
Chevy 292 Timing Question BIG292 Engine 8 07-29-2007 10:58 PM
Small block chevy timing Anton Engine 1 06-16-2005 11:27 PM
