Timing a 75 Pontiac 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2008, 05:49 PM
Ok, 1st engine rebuild. '75 Pontiac 455. I just got it running and I'm looking to set the timing. I'm told around 35 degrees at 3500 rpm with vacuum disconnected? There’s one line marking on the balancer, and the timing chain cover has a outcropping marking the 4 – 8 – 12 degree marks. How in the world do I tell where the 45 degree mark is? And is my info on the timing accurate? How does one set the timing here? At idle it’s set to 8 degrees.
Old 11-01-2008, 06:16 PM
Jmark's Avatar
Hi and welcome to the HR forums.
First off, depending on the build of the engine, those timing numbers may be way too high, or ok.
To check the "total" timing, you need an adjustable timing light. It can be "dialed" back to show the zero marks on the tab/balancer and then read on the light.
If you can post the engine particulars, the Pontiac guys can give you some suggestions.
Mark
Old 11-01-2008, 06:37 PM
re timing a pontiac 455
Edelbrock PerformeAr plus cam, lifters and intake manifold, performer model 1411 “adjusted for fuel economy” 750 cfm carb, MSD pro billet distributer. Heads say 6H, all new but stock crank, rods, pistons, valves springs, everything including the water pump …etc Plugs gapped at “if I remember right” 50, maybe 60? Pontiac “Ram Air’ exhaust manifolds.
And thanks!
Old 11-29-2008, 10:18 AM
455 timing
12 degrees initial at 850 to 1000 rpm - vac unplugged - should put you near 36 total. You will need to listen for spark knock under load but with 6h heads you only have about 8 to 1 compression ratio.
455 Olds timing marks 71cutlass0159 Engine 6 01-26-2007 06:59 AM
Will a pontiac 455 go in my 65 Wildcat? rezervation_pitbull Engine 3 06-29-2006 04:09 PM
timing spec for 73 olds 455 stock engine Cutlass327 Engine 2 04-27-2004 04:46 PM
Pontiac 455 or 400 Which is the better engine? johnvomit Engine 10 01-11-2004 05:56 PM
pONTIAC 455 ENGINE 1972 Gawthrop Engine 4 05-20-2003 09:44 AM
