Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing 86 305
Thread: Timing 86 305
Old 10-06-2012, 09:13 PM
cdminter59 cdminter59 is offline
Timing 86 305
When you changed the timing gear set were the dots on the crankshaft at 12:00 position and camshaft at 6:00 position? Do you remember where they were aligned when you took the old timing chain off? When checking the timing is the vacuum hose disconnected from the distributor and plugged.
