Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing 86 305
Thread: Timing 86 305
Old 10-08-2012, 08:15 PM
cdminter59 cdminter59 is offline
Timing 86 305
How are you setting the timing? Do you have a timing light pointed at the scale and it reading 10* ATDC? Then when you try to set it on 10* BTDC it runs bad. Did you remove the distributor after changing the timing chain set? Do your self a favor and start all over. Read this article it will help. http://www.crankshaftcoalition.com/w..._a_distributor
