Timing Adjustment 351 Windsor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2003, 05:32 AM
Post Timing Adjustment 351 Windsor
I know its a dumb question, but... I own an 88 Mustang with a 351 Windsor engine and Edelbrock injection. I want to check the ignition timing and read that I need to disconnect an electrical connection to get proper initial advance reading. Can anyone explain? Also, is right front cylinder (the car's right side) the #1 cylinder?
Old 03-17-2003, 07:26 AM
aka Duke of URL
Question
[quote]I own an 88 Mustang with a 351 Windsor engine and Edelbrock injection.<hr></blockquote>
What type of ignition system are you using?
#1 Cylinder is the right front...
Old 03-17-2003, 06:34 PM
milner's Avatar
Post
if you still have stock ignition, they are talking about the spout connector. it is a small plastic block on the end of a small harness, near the dist. black or grey in colour. pull it out , set timing, install block. hope this helps!
