-   -   Timing advance (http://www.hotrodders.com/forum/timing-advance-221540.html)
dub 07-10-2012 09:14 PM
Timing advance
Hey guys,
I have a 350 bored 80 over with a mild cam. What should my tming advance be?
I cant seam to find it.
THanks,
cobalt327 07-10-2012 09:24 PM
Originally Posted by dub (Post 1572767)
Hey guys,
THanks,
Here is a page that will help.
dub 07-11-2012 12:38 AM
Thanks for the site. I tried what it suggested at 12 degrees, hard to start now so I think Ill try 18 and see what happens.
Thanks,
Mike
hobbles 07-11-2012 04:59 AM
Try 10 degrees.
Undo the vac advance..
zildjian4life218 07-11-2012 05:44 AM
If it was hard at 12* 18* will be worse. Go through the link that Cobalt posted it will help you setup everything like it should be.
hobbles 07-11-2012 06:41 AM
Mine didn't like 12 either, but it likes 10,, CLICKY. (22 seconds)
cobalt327 07-11-2012 08:56 AM
Thanks,
Mike
Most SBC engines- even w/a stock cam- will tolerate 10 degrees BTDC.
If by hard to start you mean the starter seems to drag, you need less advance as suggested by zildjian4life218. If you mean it turns over normally w/o any starter drag but takes a long time to start up, it may want a bit more timing, the choke may need adjustment, or your start-up procedure may need tweaking.
spinn 07-12-2012 11:59 AM
That is a very good timing link. It says it all.
My mild performer cam likes 14 and 21 at 3000rpm from the manifold. The Vacuum advance is adjusted for 8-10 more at whatever inches of vacuum the turns are set.
For slow/hard cranking .Check the wires to the starter if there is only one small gauge from the battery. Wrap 2 same gauge wires to the starter together. It puts the circut in parallel . Doubles the amps to starter but keeps the voltage the same.
Like 2 sets of jumper cables on a dead battery.
