Timing advance - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2012, 09:14 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Timing advance
Hey guys,
I have a 350 bored 80 over with a mild cam. What should my tming advance be?
I cant seam to find it.
THanks,
Old 07-10-2012, 09:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by dub View Post
Hey guys,
THanks,
Here is a page that will help.
Old 07-11-2012, 12:38 AM
dub's Avatar
dub dub is offline
Thanks for the site. I tried what it suggested at 12 degrees, hard to start now so I think Ill try 18 and see what happens.
Thanks,
Mike
Old 07-11-2012, 04:59 AM
hobbles's Avatar
Try 10 degrees.
Undo the vac advance..
Old 07-11-2012, 05:44 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
If it was hard at 12* 18* will be worse. Go through the link that Cobalt posted it will help you setup everything like it should be.
Old 07-11-2012, 06:41 AM
hobbles's Avatar
Mine didn't like 12 either, but it likes 10,, CLICKY. (22 seconds)
Old 07-11-2012, 08:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks,
Mike
Most SBC engines- even w/a stock cam- will tolerate 10 degrees BTDC.
If by hard to start you mean the starter seems to drag, you need less advance as suggested by zildjian4life218. If you mean it turns over normally w/o any starter drag but takes a long time to start up, it may want a bit more timing, the choke may need adjustment, or your start-up procedure may need tweaking.
Old 07-12-2012, 11:59 AM
spinn's Avatar
That is a very good timing link. It says it all.
My mild performer cam likes 14 and 21 at 3000rpm from the manifold. The Vacuum advance is adjusted for 8-10 more at whatever inches of vacuum the turns are set.
For slow/hard cranking .Check the wires to the starter if there is only one small gauge from the battery. Wrap 2 same gauge wires to the starter together. It puts the circut in parallel . Doubles the amps to starter but keeps the voltage the same.
Like 2 sets of jumper cables on a dead battery.
350, chevy
Timing / advance eatonde Engine 1 10-08-2008 04:48 AM
timing and advance bradykat Engine 2 06-27-2008 01:40 AM
How Far Should I Advance Timing leejoy Engine 11 06-19-2006 09:02 PM
to much timing advance stinky jinx Engine 0 06-03-2004 08:30 AM
Base Timing - Advance timing chevelle67 Engine 3 05-11-2004 07:45 AM
