Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - timing advance on a lightly built 350 (300 horsepower)
Old 09-14-2011, 07:35 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by Ocean-Angler
There is no vacuum advance on this.
Is the motor going into a boat or aircraft or is strictly an off-road motor? If this is a street driver, then you have screwed the pooch.
Im in the process of installation and wanted to know what the idle timing should be
Stock to mild aftermarket cam, 12 degrees. Total 36-38 depending on chamber size and shape, all in by 2800-3000.
compression is porbably around 9- 9.5 :1
Bull Hockey. If you don't know the exact static compression ratio as determined by measuring all components, then you have no idea what cam the motor wants. You have screwed the pooch.
headers
Care to elaborate?
2000 stock stall
If this is a stock converter, it will not stall at 2000. You have screwed the pooch again.
