timing advance on a lightly built 350 (300 horsepower)
Hey guys
I just bought my MSD pro billet mag pickup dizzy. There is no vacuum advance on this. Im in the process of installation and wanted to know what the idle timing should be, that will give me a starting point as to which advance kit I want to use. its a rebuilt 350 has stock heads with pocket porting, port matching, valve lapping, basically a full blown hand porting job, ( milled .35 thousandths too) minus valve seat grinding. compression is porbably around 9- 9.5 :1 tuned and rebuilt Q-jet to match all the specs headers 700r4 trans , 2000 stock stall 3.55 gears, small tires ( high rpm) mild Melling MTC-1 Cam and lifters ( hydralic flat tappet) WHat should my initial idle timing be at on this? 16 degrees? And what should my total timing be? With the MSd, I can tailor the curve to hit total advance in a wide range of RPMS, so thats what I want to figure next Last edited by Ocean-Angler; 09-14-2011 at 04:18 PM. |
what in the HELL!!! LMAO crap
Well hopefully when i elaborate ona couple things, I wont have screwed the pooch too much haha Quote:
And the reason I did that, is because I found a good deal on a CRANE HI6-N ignition box, which required a very specific MSD or other dizzy, but the MSD version didnt have the vac. advance... Quote:
For the cam, I went with an older engine balancer/machinist receomendation. Hes been doing balancing and machining for about 30 years. I explained to him the details of the motor, and had him mill the heads and give me tips on porting. He suggested in the cam, its a notch above stock, split duration. Quote:
will be changing the stall to a serious billet machined 2600 Loose stall when I get the ignition system dialed in |
here is a nice timing link.
has some timing numbers towards the end of the article. http://www.corvette-restoration.com/.../Timing101.pdf |
Having a vacuum advance has far more advantages and basically no drawbacks on a street driven engine. It aids economy, it will allow a cooler running engine, at idle especially. It can help smooth the idle. Definitely a good thing to have. Quote:
To compute the CR you need to know the head gasket and cylinder bore diameter, the stroke, the piston deck clearance (how far down the hole the piston is), the head gasket thickness, the piston volume and the chamber volume. If you don't know these figures, you're guessing and the difference could easily be more than a 12% variation. The large chamber SBC heads are crappy flowing and the chambers are inefficient. Given that, the work you did may or may not have actually helped flow- w/o a flow bench, this is a crap shoot once you alter the stock port profile. Just cleaning up the ports and port matching the heads to the intake can help. I seem to get that you didn't get a valve job done. And that means that likely the guides are also untouched. These two areas are wear points that have to be addressed on every used SBC OEM head I've ever seen. The guides always wear and are loose after being used for any real length of time. The seats being done correctly w/a multi-angle valve job and back cutting the valves will give you more flow increase at the lifts where it matters most, than most anything else a home porter could ever hope to accomplish unless the home porter has a lot of experience and/or has served under a pro. Quote:
Looks like the amount of money I spent on this motor, I shot myself in the foot. THe origional idea was just to give it a little power, till IU bought my LS2 motor and built that a little. But after everything, Ive overspent on a motor that wasnt properly tuned it looks like Cam specs - .050 duration - 204 intake 214 exhaust sae duration - 278 intake 288 exhaust valve lift .422 intake .444 exhaust Lobe separation - 107 int 117 exhaust .050 timing BTC -5 ABC 29 BBC 44 ATC -10 (??) engine is a goodwrench crate 350 with stock 8:1 compression ( if that helps for compression calculation) I didnt get a valve job done, I spent quite a bit of time lapping the valves, also cleaned the valve bowl really well. I couldnt fit long tube headers, theyd be about 1.5" off the ground if I put them on car weighs 3600 lbs I dont know if any of this helps.. With that non vacuum advance diz, do you think its really gonna kill me on gas? and rough idle? |
[QUOTE=Ocean-Angler]Hey guys
I just bought my MSD pro billet mag pickup dizzy. There is no vacuum advance on this. MSD explains it pretty good here... http://www.msdignition.com/instructi...df?terms=85551 |
The vacuum advance not being there is something that can be dealt with as easily as buying an eBay Skip White HEI distributor w/vac. adv. or just locate a good used GM Delco HEI distributor w/vac. adv. and the "4-pin" module. These were used in cars through '80 and some trucks through '86 and aren't hard to find at all. Sell yours to get your money back- or most of it, anyway. The guides and the lapped in valves may or may not be a problem- you can check the valve seal, but that really doesn't tell you too much. The problem w/lapping valves to try to regain the valve seal is the guides- if not replaced- will allow radial runout of the valve and when you combine that w/lapping, you can end up w/the seat off center, etc. Just not an effective way to do it. Choices as I see it, is to run them as-is and hope for the best, or bite the bullet and have the guides and seats done professionally. I do not see the compression being a problem w/the cam you have. I would say to replace the stock valve springs if that's what you have on the heads now. Otherwise, you are fine (except for the vac. adv. and possibly the valve job issues) and the engine should be torquey and fun to drive. |
| timing help with a built motor | v8mazda | Engine | 7 | 07-11-2011 12:33 PM |
| built 305 tpi timing | dldavis | Engine | 1 | 03-16-2010 02:01 AM |
| How Far Should I Advance Timing | leejoy | Engine | 11 | 06-19-2006 09:02 PM |
| timing on a built 406 | Blob | Engine | 8 | 06-04-2004 07:27 PM |
| Base Timing - Advance timing | chevelle67 | Engine | 3 | 05-11-2004 07:45 AM |
