timing advanced!! is it needed - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-27-2013, 09:00 PM
spinn's Avatar
Please quote where I discuss boost relations with the timing curve.
I was speaking from personal experience. Thinking as the rpms continue, did I pull enough out. With shorter curves that became less of an issue for me. Then with the BTM it was problem solved.
I will not go to far or too fast with this. There is a communication issue.
I haven't discussed the operation of the btm. You cannot say I wrong in my theory yet!
  #17 (permalink)
Old 04-27-2013, 09:21 PM
spinn's Avatar
I have made my comments as clear as possible.
a supercharged combination you need something to retard the timing, as rpm increases
before the comma should be agreeable.
After the comma is referencing to my experience.
Kind of a you want this, here is why.
You can disagree. You can say , your experience, that you liked the detonation and wanted it to continue through the pull. That would be your whole deal.
  #18 (permalink)
Old 04-27-2013, 09:37 PM
33Willys77's Avatar
This discussion can/could make people question what do to... so
a supercharged combination you need something to retard the timing - yes I agree in most situations this is desired.
I see what Spinn is saying - RPMs increase - desire timing retard - when under a load - because there will be boost.
However: to clear it up, you should reference boost instead of RPM. If you have a timing curve set to reduce timing with RPM, it would be difficult to get a motor to run correctly. You can have boost starting early (for instance 2000 rpm) and so when do you start retarding the timing, and how much? If you reference boost with retard timing, so many degrees can be reduced per pound of boost. So, at 3500 RPM under load, you can have (for instance) 4-5 pounds of boost - pulling 2 degrees per pound or retard of 8-10 degrees. If going by RPM for retard timing, I could have low gears and driving 65 MPH down the highway at 3500 RPM - my timing would then be retarded. The motor would probably not like this.
As boost builds, retard the timing.
  #19 (permalink)
Old 04-27-2013, 09:41 PM
spinn's Avatar
I know what it is.
You think it said, the BTM retards the timing as RPM rises!
Please re read it.
It says something entirely different.
  #20 (permalink)
Old 04-27-2013, 09:51 PM
spinn's Avatar
I got away without retarding for boost. I kept the trans programmed like stock so the RPMS never past 4200. It was rich as hell. The whole system had to be limited to 4 psi with 92 octane fuel.
  #21 (permalink)
Old 04-27-2013, 10:32 PM
Banned
You don't retard the timing with more rpm, boosted or not. Your retard is boost dependent.
I'm not sure why you think rpm should be mentioned with boost retard at all, your initial mechanical advance curve is entirely independent.
  #22 (permalink)
Old 04-27-2013, 11:43 PM
spinn's Avatar
[QUOTE=ap72;1670736]You don't retard the timing QUOTE]
I couldn't understand the rest, or its relevance to anything I posted...
Yes, boosted you want to run a retard like the BTM. The rpm itself does not retard the timing in this case, and I never said it did.
At this point youre being difficult ( a meathead). How many posts did I make to try to explain 1 sentence. Too many. And it was not needed. You should have been able to comprehend the sentence, or explain in detail what you think I said. I have shown pictures of my truck with a BTM in place. I understand the equipment and how it works. We have not discussed this yet. Do you need to?
  #23 (permalink)
Old 04-28-2013, 12:45 AM
spinn's Avatar
Rpm matters. There is a timing curve that maxes out the mechanical advance at a RPM point. Without a BTM USUALLY you will not start detonating until rpm rise, and you have acquired some timing to the total curve.
Again, Without a BTM you will not even detonate until RPMs rise and you get to a higher timing point in the curve.
Do we need to go there? I did not feel it necessary, but now?
To be fair, AP , you know what is up. I cant figure out what this is about. I have tried my best to lay all the cards out on the table. If you want to discuss
Timing curves at RPM ?
conditions of Load ?
Experiences with forced induction ?
let me know.
  #24 (permalink)
Old 04-28-2013, 06:19 AM
Banned
I think I understand the problem, your referring to the difference in timing at rpm where the mechanical advance curve is active and I'm assuming your talking about rpm where you already have full mechanical advance.
If you compare 1000 rpm to 2500 rpm then yes rpm matters as your timing is much more due to your mechanical advance. If you compare 3000 rpm to 6000 rpm then rpm doesn't matter.
I think we're referring to two different points in the curve. An easy misunderstanding really but one I didn't consider.
Advanced Timing Question for built 4.3 S10BlazerBuilt Engine 19 10-21-2012 07:25 PM
Advanced timing 454 turchiac Engine 15 05-15-2012 04:01 PM
New motor wont run unless the timing is way advanced z-adamson Engine 18 03-30-2012 05:12 PM
SBF - Wont run unless timing WAY advanced?? z-adamson Engine 9 01-02-2011 02:11 PM
40 degrees advanced timing to run kleen56 Engine 7 11-08-2010 10:35 PM
