timing advanced!! is it needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2013, 05:16 PM
seems like a dumb question but let me explain myself!!!
I have a 400 sbc that will be running E85 and a vortech supercharger at 6-8 psi. Right now I have a vacuum advanced distrib. which does me no good because I wont make much vacuum if any.
Do i really need to have timing advanced or can i just cap the port and have it advanced all the time? I can buy a mechanical timing advanced but i have never delt with that, what should I set it to open at?
Thanks for you input
-Dana
Old 04-25-2013, 07:14 PM
-Dana
Typically the vacuum advance on a blower motor works like usual in areas where the blower isn't boosting manifold pressure. For a street engine operating under conventional vacuum conditions will be the most common condition. Therefore, the overall timing is pretty normal. But you can't have the advance all the way in all the time because as the blower pumps up the manifold pressure over atmospheric the burn speed in the cylinders also increases so a means of ignition retard is needed. So that pressure is used against a "vacuum" style advance mechanism to reduce the total advance because as the pressure and burn speed increases in the cylinders without some sort of pressure retard on the advance the engine will go into detonation. And with a blower; that's detonation on steroids!
Bogie
Old 04-25-2013, 08:24 PM
33Willys77's Avatar
It is very important to know your advance curve before you run the motor. Blower motors like/need all the intial advance they can get. Be very conservative on the timing if you are not going to have a boost retard.
Old 04-25-2013, 08:35 PM
oh man, looks like I have opened Pandoras box. The supercharger world is very new to me.
so I need to look into retarding my timing... mind blown haha, are there distributors that retard?
Old 04-25-2013, 09:02 PM
Banned
You can get a boost retard. You still need vacuum and mechanical advance though. Why don't you think you'll have vacuum? Are you using a carb or Efi?
Old 04-25-2013, 10:01 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I do not use vacuum advance on my carbed 8-71 small block pro street car, and use an MSD BTM along with an AIS injection system.
Semper Fi
Old 04-25-2013, 10:02 PM
33Willys77's Avatar
What are your engine specs (cam, compression, etc.). You may not need to have any advance mechanism (vacuum or mechanical). With the correct stuff, you can just lock out the distributor. If there is enough overlap, there is enough bleed off and the motor will not kick back. If it does, you can simply run a separate ignition toggle (spin the motor over then click it on) or get a start retard. There will probably be some others on here that will give you more advice for the SBC.
Old 04-26-2013, 07:41 AM
Banned
After the last few posts, I feel I should clarify this.
You may not NEED ignition advance, however it SHOULD have a mechanical if you do not have steep gears and a loose stall, and if you drive on the street with it at part throttle then you SHOULD have vacuum advance.
Those two items may not show up as making a difference on a WOT dyno sweep, BUT they will lead to less fuel consumption, a cooler running engine, and much increased durability.
Old 04-26-2013, 10:50 AM
spinn's Avatar
Right.
The mechanical curve sets the flame front to advance across the chamber. At low rpm it does not need to lite as far ahead of the piston coming around.
You can lock it out at 36 and drive it , in most NA cases without harm. Sometimes you can create a condition on a lean burning system where 36 will detonate. Beware. You will also need a retard/interupt for hot start if you lock it. Always run vacuum advance driving round. FI apps do not use manifold vacuum for the vacuum pod. Sometimes the emissions will clean up a little with the ported vacuum advance operating in limited capacity.
For a supercharged combination you need something to retard the timing, as rpm increases. Boogie informed you.
Old 04-26-2013, 08:25 PM
33Willys77's Avatar
Quote from Spinn: For a supercharged combination you need something to retard the timing, as rpm increases.
You should have something to retard the timing as the BOOST is increased, not RPM.
I have my timing locked @ 33 degrees - works very well and plugs read great (safe a little on the rich side at WOT). I run a 6BTM, have just installed water/meth injection, and no need for a start retard / ingintion interrupt switch. (FYI - I have a Hemi so I dont need a lot of advance) I am hoping with the water/meth, I may not need the timing retard under boost.
The Following User Says Thank You to 33Willys77 For This Useful Post:
BlueOvalTreasure (04-28-2013)
Old 04-27-2013, 09:22 AM
spinn's Avatar
Nah, unfortunately for you, superchargers are rpm dependent. So as the rpms rise.
No points awarded for correction.
Old 04-27-2013, 10:01 AM
spinn's Avatar
To explain from my point of view... Is as if you are driving and getting on it.
Your point of view would be the scientific explaination of the mechanics of it.
For some reason, I felt that I needed to shed some light on this.
Old 04-27-2013, 03:34 PM
33Willys77's Avatar
A blower will only make boost when its under a load. You could rev the engine up and past 10K and it would not create boost, unless it is under a load - and even if it was a light load on the engine, you may not reach full boost. Therefore, timing retard should be done with a BOOST retard, not a RPM retard. You only need to retard the timing under boost situations.
Old 04-27-2013, 07:37 PM
spinn's Avatar
I think there is a misunderstanding.
My comment was, For a supercharged combination you need(want really) something to retard the timing, as rpm increases.
For instance,
I stepped on the gas pedal on my supercharged engine. There was nothing in place to retard the timing. As rpm increases it still continues to knock and rattle. I should get that MSD btm to cure the condition. It would be nice to have...
Not claiming anything technical.
For some reason you said that you corrected my post.
There was nothing wrong in my post.
You should have just added your boost comment if you thought it needed to be added. Not try to tell me WHAT I MEANT in my own post.
Old 04-27-2013, 07:49 PM
Banned
Spinn, he's trying to politely tell you're wrong. And you are. Boost retard is boost dependent not rpm and boost is not rpm dependent but depends on the throttle opening (after spool up of course).
Your understanding of timing is over simplified.
Advanced Timing Question for built 4.3 S10BlazerBuilt Engine 19 10-21-2012 07:25 PM
Advanced timing 454 turchiac Engine 15 05-15-2012 04:01 PM
New motor wont run unless the timing is way advanced z-adamson Engine 18 03-30-2012 05:12 PM
SBF - Wont run unless timing WAY advanced?? z-adamson Engine 9 01-02-2011 02:11 PM
40 degrees advanced timing to run kleen56 Engine 7 11-08-2010 10:35 PM
