Timing Advancing by itself..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2013, 10:08 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Hey guys,
Quick question...My timing advance appears to be advancing itself, by itself...Sounds strange I know. Info- 72 Chevelle. 350, mild cam and bolt on's.
I adjusted the timing the other day to 16 degrees advance at a normal idle.
36 degrees total.
Driving around a for a couple days, and then out of no where, engine starts backfiring at WOT. Running like crap and so on.....
I check the timing again....and at idle its a 56 degrees advance!
I scratch my head.....re time it to the same specs above. Thinking that I didn't double check the hold down bolt on the dizzy.
I change the oil, valve cover gaskets. After I warm it up, i rev it up to 6000 RPM, comes back down to idle and then dies.
Wont start after that. A couple of strange smells, I thought I blew the motor. But.....It advanced itself again. So I brought it back to the above specs, (this afternoon) and I can tell when Im driving that the timing is changing again.
Any thoughts??
Thanks,
Mike
Old 02-24-2013, 10:21 PM
Landshark928's Avatar
FrankenPorsche
How old is the distributor? Some times the weights can get stuck, not allowing timing to return at idle. May just need a good cleaning and fresh springs.
Old 02-24-2013, 10:23 PM
dub's Avatar
dub dub is offline
Not sure how old the distubutor is. Came with the motor.... I guess i can check...
Old 02-24-2013, 10:52 PM
Sometimes under load the distributor can move if the hold down clamp is not tight enough. Can you move the distributor by hand after the clamp is set? If so, it is probably moving around at high RPM.
Advancing and Retarding Timing Linez35 Hotrodding Basics 3 09-18-2011 06:10 PM
Advancing cam timing...... 6sally6 Engine 3 12-23-2009 07:50 AM
Advancing Cam Timing ? chevy350_Camd Hotrodding Basics 3 02-21-2008 11:17 AM
will advancing cam timing 4* do what I want? Arns85GT Engine 3 09-19-2006 05:10 PM
timing not advancing mr.chevelle Engine 8 07-22-2003 03:53 AM
