Timing belt help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2006, 12:38 PM
outlaw17's Avatar
Timing belt help
Can anyone help me with information on changing a timing belt on a 99 Hyundai Tiburon , I need to know where to line the timing marks and so on . I can't seem to find any type of online manuals or anything. The engine ID is no longer on the car but its either a 1.8L or a 2.0L , I would lean towards the 1.8 because it is a single overhead cam not dual. ANYTHINg would be greatly appreciated .
Thanks.
Old 02-05-2006, 01:05 PM
DHMag's Avatar
though i despise Auto-Zone, their website has a useful guide for How-Tos. when i punched in for a 99, it automatically came up with a 2.0 DOHC. here is the link for timing belt replacement:
http://autozone.com/servlet/UiBroker...3d8004d685.jsp
i switched back to 1997, the last year for the 1.8 SOHC, and it has the same pictures, procedure. perhaps it is a DOHC with only one cam sprocket with a slave exhaust cam(connected via cam chain under the valve cover) ?
Old 02-05-2006, 02:01 PM
outlaw17's Avatar
Thanks DHMag , thats great but it's not really specific to this model of car so I am unsure about the timing marks , I'm going to look closer to see if it is obvious on this one .
Old 02-05-2006, 03:47 PM
outlaw17's Avatar
I think it is a 2.0L , there is only one engine for that year , anyways , does anyone have any way to check if it is indeed an interference engine ? I put the new belt on and fired it up , it took a bit because it was full of fuel from the owner trying to start it but once it fired it was rough and smoothed out somewhat but was still a bit rough . I only ran it for about 20 seconds because I had none of the covers or accessories on . Maybe once I can run it for a while it will clean up .
Timing Belt ap0001 Engine 2 09-20-2004 10:22 AM
dodge avenger timing belt replacement zipfactor Engine 5 04-18-2004 07:47 PM
1988 pontiac lemas timing belt removal Kat Engine 1 12-13-2003 08:25 AM
Honda Timing Belt beetle9 Engine 4 10-01-2003 03:33 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 08:47 PM
