timing chain
OK, First off thanks for answering so fast. I won't be able to check the valve train until tommorow but I do have another question. If the gear in the distributer was sheared wouldn't you be able to grab the rotor and turn it freely by hand? The rotor is in a fixed position and will not move even if the crank is turned. Unfortunately I haven't had a chance to turn the cam yet either, to see if that made the rotor turn. thanks
