-   -   timing chain again (http://www.hotrodders.com/forum/timing-chain-again-53452.html)
85 vette 12-05-2004 06:18 PM
timing chain again
One reply to my previous question said ,check to see if the pistons hit and bent the valves but aren't the pistons in a corvette and most chev350's flycut to eliminate that sort of problem? I know Jap cars have that problem but I understood that they didn't flycut their pistons and thats why they had such problems. I v'e also been told that corvette uses plastic timing gears and that they shear if you constantly pull holeshots and such. Any help appreciated
poncho62 12-05-2004 06:20 PM
Your pistons won't hit your valves on that 350. Some of the hi-perf ones with high compression i the 60s and early 70s might.
