Timing chain Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2012, 03:25 PM
Does anyone know the signs of a stretched timing chain? Reason I ask is because this things runs good right after setting tdc and dropping dist but about two starts later it doesn't wanna start unless adjustment to dist is made and it just gets worst..... Maybe stretched chain is throwing timing off with each rotation?
Old 03-03-2012, 04:23 PM
DoubleVision's Avatar
First off, what is the timing set at? second where is the ground connected?
Old 03-03-2012, 04:46 PM
maverickmechanic13's Avatar
I'll have a beer with that.
Last journal entry: My Trans Am
if its computer controlled you may want to disable the computer cntrolled advance. If its vacuum advanced you should unplug the vacuum going to it and cap off the carb. Timing should be done with the engine warmed up.
Old 03-03-2012, 05:13 PM
No computer ..l..reached tdc ....stabbed dist ...I did leave vacuum hooked up when I started ....this wasn't a rebuild just some valve seals replaced but this thing run good initially and then gets worst with each start
Old 03-03-2012, 06:01 PM
RWENUTS's Avatar
Make sure the distributor hold down clamp is keeping the dizzy in place. After you snug it down see if it will move by hand. I had one do that.
Old 03-03-2012, 06:15 PM
poncho62's Avatar
Wiki Edits: 5
To check for a stretched chain, take distributor cap off. Move your crank pulley back and forth and see how long before the rotor moves....There is your amount of play in the chain
Old 03-04-2012, 08:58 AM
Again, what is the timing set at?
Old 03-04-2012, 11:31 AM
When you say set? It's not at zero because damper on harmonic balancer is t approx 2oclock but I found tdc at high noon
timing chain setting for towing 1995 7.4L chevy 1shotcleaner Hotrodding Basics 3 03-02-2012 01:23 PM
timing chain biggiantshane Engine 13 09-02-2010 01:57 PM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 10:01 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Timing gears vs double roller chain timing chain Jag Daddy Engine 12 05-24-2003 10:22 PM
