Timing Chain Cover 1986 EFI Mercury - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2006, 09:14 PM
FORD 2DR's Avatar
Hello,
I am converting my 55 Ford wagon to a newer engine and trans out of a 1986 Mercury Grand Marquis Wagon 5.0 and Metric AOD every thing fits nicely first thing is OEM Oil pan is a rear sump, Drag link is in the way
Ok I get the front sump pan now it fits OK and clearance problem goes away by adding some 3/8 plate to the motor mounts
Then I see the timing chain cover I bought will not fit holes don't line up the line up but too small
And to top it off the timing chain has slop in it but I will change it.
Is there a $##@xx!!! timing chain cover that will fit without having to drill out the filled in hole where the dipstick and tube go and where can I possibly find it?
Any help will relieve the stress
Thanks,
FORD 2 DR
SBC, Holley floods, fixed, seems timing chain wrong 360Camaro Engine 2 09-01-2004 10:16 AM
How can I seal my timing cover on my 350sbc zachscc Engine 1 03-01-2003 06:38 PM
Engine Timing cover crank seal Buffed Engine 2 11-17-2002 07:54 PM
68 pontiac timing chain cover lil red rooster Engine 7 11-14-2002 02:34 PM
TIMING CHAIN VS GEAR DRIVES?????? GONZALEZ Hotrodders' Lounge 3 06-17-2002 08:18 PM
