Hey guys, just took off the timing chain cover on my 76 monte 305. There was a piece of rubber along the bottom where the cover hits the oil pan. It looks shot and I want to make sure that I'll get a new one with a timing chain cover gasket or front seal gasket. Any ideas?...what is this strip of rubber called? It really looks like a weak link. Thanks, Adam
Just what it is Timing chain cover gasket. There is a gasket behind the cover to the block and then one that seals between the bottom of the cover and the oil pan. Just get a kit that has the seals for the timing chain cover and oil pan and most will inc. the water pump since you normally have to tak e that off too.
Here is a link to a KIT
You may want to try a one piece oil pan gasket. There is less chance of leaks and they are reusable. They have metal grommets in them so you can't overtighten.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
