Timing chain cover zz4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2008, 04:32 PM
Will a double roller timing set fit under the stock ZZ4 timing chain cover
Thanks for any help
Old 09-04-2008, 05:29 PM
techinspector1's Avatar
Wiki Edits: 326
Isn't the ZZ4 built on Gen I architecture? If so, then any Gen I stuff ought to fit ok.
Old 09-04-2008, 05:48 PM
BOBCRMAN@aol.com's Avatar
Double roller should fit cover. But, check the block area around the cam. Some later blocks have to be relieved, around the three soft plugs, to clear the backside of the upper gear.
Old 09-04-2008, 09:00 PM
DoubleVision's Avatar
What Bob says is true. This is why Cloyes makes a "Vortec" street single roller timing set. I installed a double roller which I was told would work on my Vortec block and it did, but it was also making contact, and from the eyeball view it looked as if it wasn`t making contact but was. Needless to say, it ruined a new engine. I lived and I learned. The Cloyes Vortec set clears everything nicely. I got mine from northern auto parts for around $45
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 12:08 PM
replacing water pump - do the timing chain too? dbuff Engine 3 05-22-2006 02:35 PM
How to reseal timing chain cover to oil pan shockers69 Engine 2 06-21-2005 10:55 PM
edelbrock AL timing cover 68chevelle_ss Engine 1 03-29-2004 11:15 PM
68 pontiac timing chain cover lil red rooster Engine 7 11-14-2002 03:34 PM
