timing chain on a ford 352 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2011, 09:06 PM
This Chad from martinsville i'm trying to find out how to line the marks on my timing chain do i do it like a chevy or what need help
Old 12-24-2011, 09:12 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
bring #1 up to TDC and put the marks dot to dot.
Cole
Old 12-24-2011, 09:16 PM
timing chain
Put a big lift cam in my 352, that was guaranteed to be a ground pounder. It runs smoooth no hit. Was just wondering if I did it wrong?
Old 12-24-2011, 09:21 PM
A picture
This is the truck that i am working on!
Old 12-24-2011, 09:33 PM
points and timing
What should the points be gaped on? Also, what should the timing be set on? Thanks for the help guys!
Old 12-25-2011, 12:28 AM
Your truck look like about a 1965, or so?
Point gap, .017. Start with the timing at about 8-10 degrees BTDC, Vacuum line disconnected from the distributer, and plugged.
Drive the truck, and listen carefully for knock, or ping. If it knocks, retard it. If it does not knock, advance about 2 degrees, and test drive again. Repeat as necessary. When it knocks, retard it.
The FE engine was developed before pollution controls, and was used into the time where they added changes to help with pollution. One of the things they did was change the cam timing to the crankshaft. I believe they retarded the camshaft.
If you have an aftermarket camshaft in the engine, you may gain a bit of performance by making sure the camshaft is timed to where the camshaft manufacturer wants it. This requirements a degree wheel on the front of the engine, and a dial indicator on the number one cylinder valves.
Another "gotcha" with the FE engine is the camshaft sprocket and camshaft end play. Some sprockets have a step on them to control end play, others require a spacer to set the end play. A stepped sprocket with a spacer gives you about 1/4 inch of camshaft end play, the camshaft lobes do not hit the lifters, and the camshaft fails in a short period of time.
You need to run an oil with enough ZDDP in it to lubricate the camshaft to lifter contact. Modern oils designed for modern engines with roller lifter camshafts do not have enough of this ingredient. One oil that does have it is Valvoline VR-1 Racing oil.
Old 12-25-2011, 12:41 AM
timing
Thanks Danial
for your help i am learning all kinds of stuff on fords now that i have joyed this site. I know right much about a chevy. Fords are new to me
Old 12-25-2011, 01:13 PM
Wiki Edits: 27
don't mis up the bolts
If you use wrong bolts on the front of the engine a long one will press against the Cyl wall, cause a hot spot, damage rings,
Replacing the Timing Chain '64 Ford 390 Billy Boy Engine 14 12-26-2011 07:02 PM
Ford Modular engine: Problem with timing chain tensioner/guide design? CometCyclone Engine 2 08-23-2011 05:10 PM
Ford timing chain Robert78460 Hotrodding Basics 2 11-26-2010 10:48 AM
2002 ford 4.0L timing chain rattle fast68 Engine 10 06-12-2010 02:38 PM
Timing gears vs double roller chain timing chain Jag Daddy Engine 12 05-24-2003 10:22 PM
