Timing Chain & Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2002, 08:47 AM
Post Timing Chain & Gear
What would be a good timing chain & gear for a modified 350. I don't want an expensive set but I do want a quality set, I was planning on double row. Is it worth spending the extra cash to get a high performance set or is the economy set just a good.
Old 08-27-2002, 08:55 AM
bullheimer's Avatar
NEVER use credit cards!
Post
cheap roller chains are like $40 vs 25 for std, 31 vs 15 in summit for sbc. for $20 you cant beat it.
When is the economy anything ever as good as the quality thing?
Old 08-27-2002, 09:11 AM
Post
What about oil pumps? and what kind of specs. Should it be hi volume hi pressure or just hi volume or would stock be ok. I was thinking of hi volume
Old 08-27-2002, 10:39 AM
SJFast's Avatar
Post
High volume pumps are used when you run increased rod bearing, main bearing, and rod side clearances. If you're sticking with stock bearing specs I see no need for a high volume pump.
