Timing Chain Gear doesn't line up on the cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 08:37 PM
Hey guys quick rundown: 89 Chev truck block, originally flat tappet cam. I have and installed comp cams 08-601-8 camshaft which is hydraulic roller. The timing set i have is sealed power double roller KT3163S. The cam gear does not line up with the cam, its like the holes are out too much as if the cam is smaller or something. What chain do i need to go with? Would 1991 corvette one work or what model car would one work out of ? (ordering from local parts store)
Old 03-16-2012, 08:45 PM
DoubleVision's Avatar
It would likely be because the roller has the cam retention plate on the front of it and requires a timing set for a OEM Roller cam such as this:
http://www.summitracing.com/parts/NAL-12371043/
Old 03-16-2012, 08:47 PM
what car would that come with stock? looking to get tomorrow from napa
Old 03-16-2012, 09:09 PM
RippinRon's Avatar
91 Vette will be roller as is 91 camaro.
Old 03-17-2012, 03:24 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
If you converting over to a roller cam be sure you have the plate on front of the block between the cam and timing gear.
new timing chain and gear. Linez35 Hotrodding Basics 1 06-04-2011 04:35 PM
timing chain with a line bored block 406 ss monte Engine 3 09-20-2005 05:53 AM
454 new timing chain and gear, will not start Old and worn out Engine 6 12-04-2003 09:15 AM
Timing Chain & Gear MHenricks Engine 18 09-08-2002 04:31 AM
Timing Chain & Gear MHenricks Engine 3 08-27-2002 09:39 AM
