timing chain set questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2008, 03:51 PM
alright so i went around hunting down a timming set for my motor so i could finnaly get it in the car.but i have a few concerns and ?'s about it
first off this is going in a 3.1L 60 degree chevy v6. motor is of course turbocharged
now the factory gears are cast iron, this is what i was expecting to get in the new timing set. wlel i get home open the box and these gears look liek galvanized steel, so im assuming these are made out of the pressed metal stuff they make the spider gears for rear ends out of.now is this stuff any good or should i kepe the factory cast iron gears, which theres nothing wrong with.
second crank gear looks to be poorly machine it has a nice burr on it were the crank hole was bored, i should say looks to be more of drilled, the hole is not smooth at all, i know the burr has to come off,but what about the bore not being smooth should i polish it out real lightly with a fine drum on a die grinder??.Or once again should i just stick with the factory cast iron gears.
the cears in the set are deff not cast gears
last ? is if these new gears are fine is would lightning the cam gear do anything or is it just a waste of time, and would it weaken the gear..
heres a few pics of the set minus the chain. to me the chain in the set is the only thing that looks decent.
Old 04-08-2008, 04:54 PM
DoubleVision's Avatar
Is this a parts store replacement set? It sure looks like one. Being its turbocharged, I would bite the bullet and call the aftermarket, like summit or Jegs to see if they carry anything for it as I would think they would. I wouldnt even trust a stock replacement set on a super budget beater engine, but thats just me.
Old 04-08-2008, 05:05 PM
comp cams makes a dbl roller chain, and a billet gear/ sprocket set, these have been discontinued as far as i was told,and have not been able to track one down. as far as the stock stuff goes i know of only one person who has ever broke a stock cam sprocket, and that was on a massivley nitrous injected 3.4 which is the same motor just a larger bore. the sprocket literally broke into 2 pieces. it was never figured out what caused this.
so im pretty much stuck with stock replacements, though i have thought about having a custom gear drive made, but i dont want the noise the turbo is deff loud enough all on its own.
so my only 2 options i believe are the stock cast iron gears, or these what apear to be pressed metal gears
Old 04-08-2008, 05:11 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
In this case I agree with DoubleVision you get what you pay for, and do some other searching around for a better set. In this case I would call Summit and talk to someone and explain what you have to see what options they have available.
Old 04-09-2008, 10:59 AM
Just to update you, I did a search on Summits website and found they carry 3 sets, all made by Cloyes.
Old 04-09-2008, 11:05 AM
they also list the comp cams set but last time i called i was told it was discontinued,and they didnt have any. the cloyes set is the same as what i have
Old 04-09-2008, 12:45 PM
The sets I looked at are double roller sets, not single.
http://store.summitracing.com/egnsea...115+4294892074
Old 04-09-2008, 12:59 PM
crap i didnt even notice, yeah the set i have now is not a dbl roller,im gonan order one but it wont help me much for now as estimated ship date is 4/25. and i only have 8 days left to get this car back together.
but its not all a bad thing i was gonna have to pull a cam swap neway when i swaped out my turbo for the new 76mm unit, when i do that ill swap the stuff over to the cloyes dbl roller set
thnx fo rthat link man i never woulda noticed the dbl roller sets
timing chain or distributor? k2c1959 Engine 3 07-21-2007 04:10 PM
Need Help Choosing Cam And Timing Set 400smb_s10 Engine 1 06-11-2007 06:56 PM
Correct Timing Chain Tension mouseman Engine 7 09-20-2005 09:43 AM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 08:54 AM
BBC Timing Top Rod Engine 0 06-09-2002 09:29 AM
