timing chain when to replace? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2004, 03:40 AM
sune's Avatar
Hi.
I have a double roller timing chain in my big block chevy. I'm rebuilding the engine. The chain and sprockets don't show any signs of wear. Are they ok to reuse, and what about slop how much is acceptable in a mild 496 for the street.
Sune
Old 09-17-2004, 04:33 AM
docvette's Avatar
Wiki Edits: 12
Chain
[size=3]Doc here:
IMO: If it's open now, and your rebuilding the engine anyway, There just too Cheap NOT to replace now...and you know it's all fresh.
Better than bent over the hood 5000 miles from now...Ya Think?
Doc
[/size]
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-17-2004, 05:00 AM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Agree with Doc.If you have it out it just makes good sense to replace it.
Old 09-17-2004, 06:07 AM
GoneNova/406's Avatar
companies like cloyes make over sized sprockets for this purpose and also for blocks that have been align bored.if the chain is tight on the side of directioal rotation and a little loose on the back side you should be ok.otherwise change chain,gear or both.it doesn't pay to use a cheap timing chain and gear set up.
Old 09-17-2004, 07:29 AM
Yepp ,, replace it , wrap the old one up in a nice oily rag ,,
Old 09-19-2004, 06:16 AM
sune's Avatar
Thanks guys I guess i'll be replacing it
