Timing Change ...! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2013, 02:54 AM
Buick b4's Avatar
Timing Change ...!
Hi.
I set my timing on 10 BTDC 3 weeks ago after i asked friends here about that...!
My stock Chevy 350 worked great till yesterday as i noticed that the Temp gauge rose and car doesn't work well and the way it worked was similar to the time before i set timing...i check it today and noticed that the timing was on 7...! i adjusted it again on 10. now is it common to set the timing each two or three weeks???!!!
Thank you.
Old 09-23-2013, 05:06 AM
malc's Avatar
Living At The Speed Of Life
Sounds like you did´nt clamp the distributor down tight enough.
Or, did you check it again after clamping, sometimes it´ll move a tad as you tighten the bolt down.
The Following User Says Thank You to malc For This Useful Post:
Buick b4 (09-23-2013)
Old 09-23-2013, 06:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
To the above I'd only add that the distributor clamp bolt may be too long, causing it to bottom out before the clamp's tight on the distributor collar. EZ fix by using a shorter bolt or a washer or two under the head of the bolt in there now.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 09-23-2013, 08:32 AM
malc's Avatar
I use a stud, you´re never fiddling under the distributor getting a bolt in.
The Following 2 Users Say Thank You to malc For This Useful Post:
Buick b4 (09-23-2013), techinspector1 (09-23-2013)
Old 09-23-2013, 08:34 AM
Thats a very good idea, this is added to my 'to do' list now. Thanks
The Following User Says Thank You to Davect06607 For This Useful Post:
Old 09-23-2013, 10:19 AM
Buick b4's Avatar
Thank you...! i'm going to do it.
Old 09-23-2013, 01:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just a hint: clean the tapped hole w/carb spray (watch out and do not get the carb spray on any painted surfaces, especially the painted grill between the back of the hood and the windshield!). You can cover the hole and the end of the carb spray tube w/a rag to keep it from spraying everywhere. Then use some loctite to secure the stud in the block. Otherwise, you may eventually end up w/the stud and nut acting more like a bolt than anything.
Buick b4 (09-24-2013)
Old 09-23-2013, 02:05 PM
malc's Avatar
I´m using an ARP stainless stud and nut, it´s in there pretty tight
never backed out with the nut.
ecm change=harness change? chphlds Modern Electronic Engines 4 12-29-2012 08:16 PM
Timing change with new cam?? fosterdl Engine 3 06-02-2008 06:26 PM
Timing change JG700 Engine 3 07-21-2007 03:36 AM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
cam change - sealing the timing cover back up?? hotrodf1 Engine 5 11-22-2006 10:54 AM
