Timing Cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2008, 06:49 AM
joeford's Avatar
36 Dream
Timing Cover
Can anyone tell me if there is a difference between timing covers for different years of sbc blocks? I just ordered and received one from Summit that was advertised as "sbc" without reference to a year. Now with the timing cover in hand I note the package says, "1969-86". If this is just a style issue because it has the bowtie on it, then I'm ok, but if it will not match up, then I'm up the creek.
Old 02-28-2008, 07:18 AM
If it has a crank position sensor (vortec) then its a different cover.
Old 02-28-2008, 08:16 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I think the only difference comes into play around the timing indicator, if welded on the timing cover, it could make a difference. If it has no timing indicator and requires one that mounts using a couple of the timing cover screws then you are ok, just make sure you get the right timing indicator (pointer) to bolt up... That would be the only difference I can come up with, the timing gears and chain are the same with so the depth of the cover should not be a problem. As to up the creek those Summit guys are ok with exchanges .. they are use to it, believe me. current location Nashville Tn
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 12:08 PM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 9 12-01-2007 05:28 PM
Timing Chain Cover 1986 EFI Mercury FORD 2DR Engine 0 07-17-2006 10:14 PM
Weiand Timing Cover Roadsire Engine 5 06-16-2005 11:50 AM
timing cover to pump clearance club327 Engine 3 11-09-2003 01:52 AM
