Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing Cover
Thread: Timing Cover
Old 10-10-2003, 11:13 PM
lluciano77's Avatar
lluciano77 lluciano77 is offline
There 2 different oil pan end seals used for Chevy. One is thicker than the other. Are you sure you used the right one. If you didn't it will leak between the oil pan and the timing cover. If your leak is only at the balancer don't worry about the end seals.
