-   -   timing cover HELP PLEASE (http://www.hotrodders.com/forum/timing-cover-help-please-98947.html)
Tom31 09-25-2006 08:35 AM
Has anyone tried using a Mr. Gasket 2 Pc. Timing cocer on a 383 or 400 SBC??
What Harmonice Balancer did you use. because a stock 8" will not work. Need HELP FAST
pepi 09-25-2006 09:05 AM
May I suggest that you do not use a harmonic balancer other then the one engineered for your engine. What is the problem you are having and do you have the harmonic balancer tool?
Tom31 09-25-2006 09:56 AM
When we try to put the timing cover it is hitting. We decided to just order a new Harmonic Balancer from Jegs I guess it will work with Mr. Gasket 2pc.
That is what Jeg's said
