timing cover HELP PLEASE - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2006, 09:35 AM
Has anyone tried using a Mr. Gasket 2 Pc. Timing cocer on a 383 or 400 SBC??
What Harmonice Balancer did you use. because a stock 8" will not work. Need HELP FAST
Old 09-25-2006, 10:05 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
May I suggest that you do not use a harmonic balancer other then the one engineered for your engine. What is the problem you are having and do you have the harmonic balancer tool?
Old 09-25-2006, 10:56 AM
When we try to put the timing cover it is hitting. We decided to just order a new Harmonic Balancer from Jegs I guess it will work with Mr. Gasket 2pc.
Timing Chain Cover 1986 EFI Mercury FORD 2DR Engine 0 07-17-2006 10:14 PM
Weiand Timing Cover Roadsire Engine 5 06-16-2005 11:50 AM
sb chevy timing cover distributer?? Old School Nut Engine 20 11-09-2004 09:43 PM
timing cover to pump clearance club327 Engine 3 11-09-2003 01:52 AM
Timing Cover fred56 Engine 4 10-11-2003 03:01 PM
