Timing Cover Seal number
I am replacing the timing cover gasket and seal.
What is the best brand seal and part number I can buy. This is the last one I want to buy. I have a new balencer and am looking for a seal . |
I've had no problems from Felpro and NAPA seals. NAPA used to be the only place locally I could buy a single seal. Since then, Mr. Gasket and others have started selling seals on the performance parts asiles of the major parts stores. I have used a couple Mr. G. seals and have had no reported problems but the engines were gone from my sight shortly after being built so long term I cannot say. Be sure you lube the seal lips.
The thing that HAS been a problem is aftermarket timing covers having poorly located crank holes. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
solidaxel (12-24-2012) | ||
The seal that I am replacing is a National rubber seal and I have a new sleeve on the balencer.
The cover is a factory steel cover on the ZZ 4 engine I did pick up a small gasket kit for a cam change and the seal in the kit did not have any numbers on it so I am just checking for the best one to replace. The new seal "feels" softer than the old seal which has 40K and is 10 yrs old, I just did not like it as there was no numbers on it (cheap)!! Thanks for the info |
I have always used Fel-Pro or National seals from NAPA. Most problem leaks from the timing chain cover seal are due to a worn Harmonic balancer. It is hard to believe the seal wears a groove on the balancer.
I picked up a Timkin seal #9845 he said it was a Viton seal and should be good for 100K !!
The new positive stop valve seals are made from Viton also. Timkin either owns National Seal or manufactures them.
| timing cover seal | the other Mick | Engine | 12 | 09-29-2009 02:28 PM |
| Timing Cover Seal | boobert | Engine | 6 | 06-24-2009 11:18 AM |
| Timing cover seal | fat40 | Engine | 4 | 09-05-2006 02:23 PM |
| HELP! My timing cover seal blewout | 54 Chevy | Engine | 11 | 07-30-2003 01:26 AM |
| How can I seal my timing cover on my 350sbc | zachscc | Engine | 1 | 03-01-2003 06:38 PM |
