Timing cover, water pump, fuel pump, etc HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2012, 06:26 PM
What's up fellas, I wanted to know what seals or sealants to use on these parts I know that their usually different so help please looking forward to doing this whole thing 2moro
Water pump
Fuel pump
Timing cover gasket
Intake manifold gasket
Intake manifold edges of the block
I bought high temp gasket maker red silicone
Old 06-06-2012, 06:49 PM
Irelands child's Avatar
At the most, Edelbrock Gaskacinch (which is the inflammable contact cement), or a spray on contact cement such as Permatex. Many of the RTV/silicones are dissolved by petroleum products unless it specifically states it's good. Timing covers, fuel pump gaskets, water pump gaskets and timing cover gaskets, if premium quality don't really need any sealant. Intake gaskets - you need to follow the gasket manufacturer's instructions as to what and if they need a sealant. Some do say what to use, others, none is needed. Valley covers/manifold ends=the red will work fine.
Old 06-07-2012, 06:44 AM
Ultra copper or permatex is all i use with great results
Old 06-07-2012, 06:46 AM
Non SPI THUG/Not Sheeppeople
Last journal entry: 700r4 still running strong
I use the black silicone for almost everything now.I hope someday theyll improve the cap that seams to split right in the middle,then you have a nice dry plug youll have to dig out.
Ford 302 Water Pump/timing Cover 65ELCMO Engine 11 12-30-2011 07:56 PM
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
fuel pump and timing cover question 49fordp/u Engine 7 02-07-2008 08:15 PM
Timing cover and water pump SpeedCrazy Engine 9 12-13-2004 10:24 AM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 09:29 AM
