timing curve - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2007, 05:13 PM
timing curve
When should I be all in? I have it set 36 at 2,800, would soner or later be better?
55 chevy 71 350, trickflow heads 228/236@110 487/492 lift. Th350 2,500 stall 4.11.
Old 07-01-2007, 01:58 AM
techinspector1's Avatar
Wiki Edits: 326
I'd set it the same way if it was mine. You might try backing off the initial by 2 degrees and try it at 34@2,800 just to see if it likes it or not.
Old 07-01-2007, 02:01 AM
ericnova72's Avatar
More for Less Racer
timing curve
Where you're at now sounds good, maybe get it all in by the time the converter stalls. Only way you're ever gonna know is track times or chassis dyno, you're not going to be able to tell by the seat-of-pants method -- the difference is just too small.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
305ci Timing Gear Marks Do Not Line Up tcruise Engine 9 08-30-2005 06:22 AM
optimum timing curve fiscus Engine 1 08-04-2005 05:36 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
Timing problem - Help MTMike Engine 1 11-13-2002 01:07 PM
