timing\dist\or curve? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 08-08-2004, 02:13 AM
I have a 72 Ford Coriour whith A 68 302 in it.Every time I try to hook up my vac\advance it would make a loud clacking noise with the rotation of the distributer.So one day I decided to take a look and I found a worn out spring.So I replaced it,and the noise went away.Now I cant get the thing to get out of its own way.Its fine at idle and low speed but when you put your foot into it .It pops and spits and looses power.It ran ok with the vacuum advance plugged up but bad gas milage.I tried adjusting the points and the timing nothing works.Could my distributor be off?The only other thing I can think of is I used the same springtention when I replaced the springs, or should it be heavy and lite! I wouldnt think that would cause that big of a problem.Hope you can help thanx. Hey guys and girls If I am in the wrong forum let me know [first- timer]How do you change forums?
Old 08-08-2004, 06:30 AM
aka Duke of URL
Arrow
It's obviously the wrong spring or the pivot/bearing assembly is worn on the breaker plates. You need to make certain the plates are good and if so get the correct spring(s) and/or have it recurved.
Old 08-08-2004, 10:11 AM
Is the pivet bearing the brass looking thing on the the plate that when you slide it over the pin it touches it ? If this it is wobbled out.
