timing? exhaust or intake stroke? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 11:27 PM
jesse01's Avatar
mini me
I recently changed my headgaskets on my 92 roadmaster, but during the preocess the underdrive pully must of turned somehow, but I didn't relize it till after I put everthing back together and went to put the distrubter back in, & the rotor did not line up on the mark I made
I know to put back in time you normally put the #1 cylinder at TDC & put the rotor on the distrubter pointing towards the the #1 spark plug wire tower on the distrubter cap. right?
my question to you guys is:
does it matter if the #1 piston is on the exhaust stroke instead of the intake stroke when you go to do this procedure?
If so how can I tell w/o ripping it back apart?
before anybody says "check your timing marks on the balancer w/ a timing light" just to let everybody know I don't have a timing mark indicater thingy on my timing chain cover to check my timing marks on the balancer w/a light
any input on this would really ease my mind. especialy since I have to have this *@#% car done by mon. so I can go to work and get the kid to school
Old 03-19-2005, 11:38 PM
nicowarrenrogers's Avatar
as far as ive heard when timing the distributor it has to be on its comression stoke.
Old 03-20-2005, 07:53 AM
Yes it matters it has to be the compression stroke.
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
Ignition timing curve help? Ratchet Engine 14 01-28-2005 01:27 PM
exhaust and intake valve clearance for a 1987 350 C 10 jpeterson Engine 0 02-20-2003 08:59 AM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
