Timing for fresh rebuild 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2010, 05:52 PM
V305's Avatar
On the Border
Hi guys, this is a great site. I need help setting the best timing on my new 350 thatīs already on my car, I just installed the distributor, intake, carb and itīs running, I installed the distributor putting the n.1 piston on TDC (well putting my thumb on the spark plug hole) I donīt know nothing about timing, I can ask a mechanic to do it but I dont know if this parts changes the curve on the engine:
*Edelbrock cam 2102 (0.420 int./0.442 exh. Duration 278 int./288 exh.)
*Edelbrock performer EPS intake
*Holley 0-1850S 600 CFM Vac sec
*Hooker Headers 2451HKR with 2.25 H-pipe
*MSD ignition 6A, MSD cap with stock HEI coil and stock HEI distributor
*MSD heli core spark wires
*NGK spark plugs with 0.045 gap
PS: Sorry for the long thread
Old 08-26-2010, 06:25 PM
techinspector1's Avatar
Wiki Edits: 326
Camshaft duration @ 0.050" tappet lift is 204/214. Run 10-12 degrees at the crank, total initial and centrifugal will depend on the chamber design. Older heads may require up to 38 degrees. Modern fast-burn chambers may only require 34. Alter the centrifugal curve to provide whatever total you want to use, all in by 2800. Plug vacuum advance into the intake manifold, not the ported nipple on the front of the carb.
Old 08-26-2010, 07:09 PM
user151's Avatar
If I recall, manifold vacuum is available on the front of the base plate, under the fuel bowl. The nipple aims to the passenger side. Of course you can plug directly into the intake manifold also.
Ported or timed vacuum is not on the "front" of the carb but on the passenger side of the front metering block.
But maybe that's what you meant.......
Old 08-27-2010, 05:58 PM
V305's Avatar
On the Border
Thank you guys
HELP! Rebuild 350 vs. Drop 327 in my 63 Impala Super70 Engine 9 03-31-2011 11:27 AM
first 350 rebuild campracing Engine 8 09-10-2009 01:30 PM
403 olds big block versus 350 target master rebuild dustin.campbell3 Engine 18 08-26-2009 06:12 PM
Timing question on 350 sbc eric32 Engine 6 08-03-2009 07:10 PM
Timing for my 350? fastrehotrods Engine 16 12-11-2006 09:49 AM
