timing gear marks - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2004, 09:26 PM
timing gear marks
I bought a summit double roller timing chain for my 283 SBC. I am ready to install the timing chain but i have a small question. First should I install the chain heads up and not +4, -4 degrees advanced/retarded? I was planing on going staright up. And when i look at the bottom gear that goes on the crank the manual tells me to line up the two dots. The dot on the large gear is hard to miss, but the small gear has two dots, a couple triangles and some boxes, like a damn geometery book So when it tells me to line up the dots i assume it means the dot that is directly over one of the key slots, while the other dot is about 30 degrees away from that dot.
Any help would be great!
Old 04-06-2004, 10:08 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Don't know about all of your markings, but the key way on the crank should be about 2:00 o'clock, and the dot on the crank gear will be actually between two teeth. Time it straight up.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
