timing gears need grinding - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2011, 06:04 AM
MAKE EM STICK AND E.T'S QUICK
i just bought a dual idler noisey timing gear drive for my 327. i installed the cam, thrust bearing, cam and crank gears, and the cam "button". but i have to grind the cam button to clear the timing cover a lil and i have to grind the power idler axle on the block side. does anyone have any tips for me not to grind to much off.
Old 01-21-2011, 12:03 PM
i think you grind the block & not the idler gears, also you don't grind on the cam button. you dent the cover for clearance.
Old 01-21-2011, 10:43 PM
the instructions say togrind the power idler axle, not the gear its self, and to slightly grind cam button. but i was going to just dent the cover.
noisey timing gear drive needs grinding crankshaft3rd Engine 3 01-21-2011 08:19 AM
timing gears suburbanguy Engine 2 07-30-2009 03:59 AM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
TPI with timing gears karlseus Engine 2 11-14-2003 10:25 PM
