For the timing guru's - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2010, 04:18 PM
Ok so im nearing completion of my 355 build and wanted to get a handle of timing before I even think about firing it. My engine consists of:
Stock .030 over block
reconditioned rods, crank
mahle flat tops 6cc .025 in the hole
fel pro 1094 .015 shim gasket
bowtie phase 2 heads 63cc
cam dynamics 284, same grind as crane cams energizer 284
all accel hei ignition
My questions are what should i time this at and how exactly do I do it. Ive always kinda timed by ear but i really wanna dial this motor in. I read of people talking about total timing at 34-36 degrees, and i am completely lost on how this is figured when the marks on the pointer only show timing for the initial timing. I am a complete newb to timing so if anyone could give me run down on what i should time my motor at and exactly how the procedure is done, thanks!
Old 05-11-2010, 05:23 PM
You verify top dead center with your balancer mark and your pointer 0 on your timing tab, then I buy the correct size timing tape for your balancer around 5 dollars and put this on your balancer. Then as you bring your engine rpm's up to usually 3,000 rpm's your total timing should be between 34-38 degrees total. Every engine is different based on combination, of the total timing amount.
Old 05-12-2010, 09:35 AM
Thanks for the replies, f-bird so I'd want my advance to locked out before the powerband of my cam? Around 2,800..I'll do that and I usually just advance till it pings and back it off until it stops
Old 05-12-2010, 10:25 AM
Thanks for the info!!
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 12:35 PM
Sbc 02 Crate Engine. Timing stubborn72k20 Engine 1 02-19-2010 08:05 AM
sbc timing question 350pano Engine 8 05-15-2009 10:30 AM
Timing Timing Timing bigcountry1009 Hotrodding Basics 6 01-20-2009 05:47 PM
