Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing by hand...
Old 12-02-2004, 07:25 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
If the car starts, you can also time it by using a vacuum gauge off a vacant port on the manifold. Adjust the distributor until you have the maximum vacuum and then retard it a degree or two.
Dewey.
Always learning...and sharing what I've learned.
