Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing by hand...
Old 12-05-2004, 12:02 AM
lluciano77's Avatar
lluciano77 lluciano77 is offline
Originally posted by cboy
If the car starts, you can also time it by using a vacuum gauge off a vacant port on the manifold. Adjust the distributor until you have the maximum vacuum and then retard it a degree or two.
Dewey.
That is not a very good method.
The best way is to get an advance analyzing timing light and do it right. The time and money for a teardown to change a blown head gasket etc. will warrant the cost of the timing light.
