Timing hassels - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-21-2006, 08:54 AM
Very informative thread for those of us who rarely get down to self tuning! I'm just wondering if the timing specs shown here differ a lot for a big block? One friend has a 427, mildly done & I have a '67 396 virtually stock!! Thanks in advance!
  #32 (permalink)
Old 04-21-2006, 09:17 AM
Frisco's Avatar
Glad To Be Here
The procedure would be similar. The idea is to get maximum advance with no 'pinging' for maximum performance. Most V-8 engines will run very well with more advance than the factory specifys.
  #33 (permalink)
Old 04-21-2006, 09:38 AM
al37ford,
agree with Frisco, procedure is usually the same but you do need to know what was the stock base for each motor
ex:
350 chevy 12*stock typical it likes about 16*
350 olds can be 20* stock base, set it at 16* it runs like a dog
351W ford (and 327 chevy?) 8* stock, set it to 16* knock like hell and probably 4 batts to start it hot if it did run
quick shortcut for any motor stock timing: autozone.com under repairs-tuneup-timing....just plug in which motor
  #34 (permalink)
Old 04-21-2006, 11:15 AM
al37ford,
footnote:
the "stock" motor base timing setting is factory chosen compromise setting so the motor will start and run no matter where for altitude/temp extremes, (dead cold on a mtn top in Alaska Feb or hot in FL sea level in Aug)
some factory manuals will have a footnote: " base timing can be increased to improve performance by up to "X*"..."
most (?) stock motors are alot more "perkier" with a couple of degrees above stock
Timing Marks ??? Zeder Engine 10 06-18-2013 05:19 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
BBC Timing Top Rod Hotrodders' Lounge 4 11-13-2007 11:48 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 02:35 AM
BBC Timing Top Rod Engine 0 06-09-2002 09:29 AM
