Timing help - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-17-2013, 10:32 PM
vinniekq2's Avatar
698 hp is very mild for no limit racing.sounds like you use high compression and racing gas?900 hp is do able in a mouse
  #32 (permalink)
Old 04-17-2013, 10:45 PM
Yes 13.5:1 and 114 race gas. I know 900hp is do able but I don't have 15 to 20k to do it. I have 3500$ for almost 700hp and I can win with that so I'm happy. My heads have a lot taken off of them and I don't have much room left to go to a bigger cam. I just need it to run top notch so I can go kick *** again.
  #33 (permalink)
Old 04-17-2013, 10:59 PM
vinniekq2's Avatar
keep us all posted,,
will wait for a video too,have fun
  #34 (permalink)
Old 04-19-2013, 05:54 PM
Tried a brand new regular inductive light and have the same issue. Pulled the motor and had a builder come look and put the degree wheel on it. It's all good but I'm still showing crazy timing numbers. I replaced the magnetic pick up in the distributor before all this and I'm wondering if the magnet is to close to the reluctor. It's only about .03 gap would that cause a false reading or anything? Took the car down my long flat driveway and the car runs great just tuning it by ear. My old man is dead set on that method. Lol any other ideas? Trying to track down another distributor to see if anything changes.
  #35 (permalink)
Old 04-19-2013, 08:01 PM
Another question, I changed msd boxes as well and went to a used untested to me box. Would a bad box cause bad timing reading?
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 01:08 PM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 10:01 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
