Timing help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2013, 06:48 PM
Timing help
I have a 418 sbc race engine with -10 brodix alum heads. 588 lift and 260 duration roller cam with dome top pistons. Msd ignition. My problem is when I put my timing light on its showing around 47*. When I bump it down to 34 or 36 the car will not restart. It acts like its way retarded. I have to advance it back to get it to fire. The car doesnt start hard though at this timing. I've tried using a different battery outside of the car to make sure it wasn't the battery or wiring in the car. The cam was installed heads up but not degreed in( same exact setup as I ran before the engine was just rebuilt) I just replaced the magnetic pickup in the dist and thought maybe I got the 2 mag wires backwards so I swapped them but no difference came from it. I'm trying to get another timing light to see if mine is bad but are there any other ideas? First race is Friday and I'm not comfortable running it without knowing true timing. Thanks
Old 04-16-2013, 06:57 PM
techinspector1's Avatar
Wiki Edits: 326
There's only one way that I know to do it.....
http://www.crankshaftcoalition.com/w...op_dead_center
Old 04-16-2013, 07:01 PM
So the cam needs to be degreed in?
Old 04-16-2013, 07:03 PM
Wiki Edits: 326
Ignition timing cares about where the piston is when the plug fires, it does not care about where the cam is as long as both valves are closed.
Old 04-16-2013, 07:04 PM
K. I'm confused. I get what you said but not sure what I need to do I guess.
Old 04-16-2013, 07:25 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Did you read the coalition link Tech gave you? You need to verify TDC for the #1 piston, and ensure your timing mark and pointer is spot on.
Semper Fi
Old 04-16-2013, 08:07 PM
Ok. Sorry, I'm new to this stuff. After reading it a few times what I got was if tdc is showing,say 20* I then just make a "new" 0* mark there then set my timing accordingly? Will the engine still perform its best doing this or do I need to have the cam degreed in with a wheel and move timing gears if need be? Thanks for the info.
Old 04-16-2013, 08:24 PM
64nailhead's Avatar
Dude, that's alot of engine ($) for being 'new to this stuff.'
Degreeing the cam is great, but the first step of degreeing the cam is to find TDC#1. I believe that is what Tech and 68Nova are trying to tell you.
Once you find #1 TDC then look at your timing mark on the crank pulley/balancer. From the sounds of what you're describing, the mark won't be lined up with your timing pointer. There are several reasons this could be. If the engine runs properly, then the balancer could've slipped, the timing indicator you're using is not correct for the crank, or vice versa.
10-4 on not trying to race it without knowing exactly where the timing is.
Good luck.
Old 04-16-2013, 08:28 PM
I'm used to running a gm crate engine and switched to an "open class". I think I get it now. Ill pull the engine and put a degree wheel on it after going through and finding actual tdc. Thanks
Old 04-16-2013, 08:43 PM
vinniekq2's Avatar
most race organisations insist on a safety type(sfi approved) balancer/flywheel/clutch
Old 04-16-2013, 09:02 PM
Everything is sfi rated and up to 10k. Found my tdc tool. When I bring #1 to tdc my pointer and timing tape meet at 0*. What next? Degree the cam right?
Old 04-16-2013, 09:13 PM
vinniekq2's Avatar
you are degreening the ignition and verifying that the mark on the balancer is correct.If its SFI approved and has slipped,get warranty.
Old 04-16-2013, 09:20 PM
So even though tdc on #1 lines up with 0 on my tape the balancer ring may of slipped? Is that what you are telling me? When #1 is tdc the #1 plug wire is about 1/8" retarded in relation to the rotor but my last timing was saying 44* is this info helps.
Old 04-16-2013, 09:27 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Also, and I didn't see it mentioned, you don't want the vacuum advance hooked up when you set the ignition timing.
Bill
Old 04-16-2013, 09:31 PM
No vac advance. Distributor is locked out
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 01:08 PM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 10:01 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
