timing help again - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2013, 07:11 PM
Proud LOSER
timing help again
Hey again, OK, so installed my accell vacuum advance can tonight. Also got the carb on as well.
Initial start up was fine, when i installed the VC can I simply removed the cap, the rotor, the 2 screws holding the vacuum can, slid the pin down till it was free, reinstalled the new one the same, reinstalled all. Start car, VC advance plugged for now, timing still the same at 26 initial, 36 total. Set idle, mixture screws etc. Still seems rich at idle, but figure I will hook up yje vacuum advance and see how it works. Timing now at 36* but doesn't fall off with rpm. Vacuum advance and total brings it to like 50 at 3000rpm. And timing pointer at balancer is now jumping around, let it idle down, its still showing 50*. Crack the throttle a few times and it comes back, but is erratic. Wth! The only thing that seemed out of place was I'm almost sure I heard a "crack" sound when trying to tighten down the cap at the rear hold down. Had music on so wasn't sure. If the cap has a small crack in it would this send the timing all over the place? Or did I disturb the weights somehow and not set them back in the right place. I didn't think I moved them at all. And they have less then 5000k on them and do look brand new.....so.....? Help? Were supposed to be headed to open night at the strip tommorow night and I need this running.
Thanks
Dave
Old 05-16-2013, 08:50 PM
Proud LOSER
Disregard...fixed.
Thanks
Dave
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 02:08 PM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 11:01 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 09:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 08:54 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 02:35 AM
