timing help with a built motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2011, 04:04 PM
havin fun
*sigh* frustration is setting in. ok 350 .06 over with vortec heads, dual plain intake edlebrock carb. voodoo cam 268/504. not sure if you needed that info but in case you did that's the build in a nutshell. i built the motor and painted the car and even did some of the machine work(work at a machine shop) and this was my first solo build so i'm dieing to get this thing right. my issue
i cant figure out how to tune this thing. when i time it where i think it need to be it runs for crap. my timing indicator is the stock one that has 3 triangular notches one of which is bigger then the others. i thought that was -0- when i turn the distributor and get the mark to move to toward the passenger side it runs better but then when i drive it down the road it wants to spit and sputter. if i turn the distributor till it sounds good and responds good to throttle it will scream down the road but i can still feel its off some... can someone just throw some things out there for me to think about and check? I'm kinda a newbie and have never tuned in a new motor.
thanks
brian
ID:	56762   Click image for larger version
ID:	56763   Click image for larger version
Old 07-10-2011, 07:57 PM
havin fun
nobody any input would be appreciated.....
Old 07-10-2011, 08:11 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Do you have a good timing light ?
Cole
Old 07-10-2011, 08:29 PM
Richiehd's Avatar
JS-70
Cole
Cole is right. You need a timing light with an advance dial on it. Assuming your timing mark is right on, advance the timing until you have some where around 36-38 degrees total timing. Understand? You will be setting the mark to 0 with the degree dial set at 36. Not quite sure how to explain it better
Old 07-11-2011, 06:27 AM
havin fun
no i dont fully get it cole. i just bought a new timing light its a basic "inductive" light i so dont want to have to take this car in to a shop to have it done. i'll keep reading on it online and see if i can understand it better. thanks
Old 07-11-2011, 08:17 AM
75chev4x4's Avatar
I dont fully get this either. My timing light has no dial and I can't get my motor timed correctly. Can someone explain this?
Old 07-11-2011, 08:51 AM
75chev4x4's Avatar
you dont need the advance light if you buy a balancer cover that has all the degrees on it correct?
built 305 tpi timing dldavis Engine 1 03-16-2010 03:01 AM
Turning Newly Built Motor nootkabear Engine 43 03-19-2008 02:56 PM
whats the best sbc motor ever built denny1977 Engine 12 01-22-2006 06:18 PM
timing on a built 406 Blob Engine 8 06-04-2004 08:27 PM
Compression reading on a new re-built motor? 11echo Engine 4 04-02-2004 02:27 PM
