With traction, you have the potential to run 13’s.
From what I’ve heard about the heads you’re using, around 34º seems to be their ‘sweet spot’, and I doubt if there will be any real gains from going higher, w/only the risk of detonation as the reward. That cam is not so radical that you couldn’t set the ignition up w/a timing curve, but by the way you explain it- there may not be much if anything to be gained. You sound a little like a (recently banned) member who has a similar set-up (his is a 383, IIRC)- he also says his performance is great w/o a curve and locked at max. I’ve said it before- if it works for YOU, then go for it. But a back-to-back comparison on a track is the best way to evaluate just what IS happening, IMO. Also IMO the cam specs aren't so 'big' that locked timing is required. It does make setting up the distributor easy, though! lol I see only 185 and 190, and bigger, but not 195cc runners. Last edited by cobalt327; 08-02-2010 at 08:36 AM. |
Check out the posts HERE, there is some more good info on timing in general and vacuum advance in particular that you may find interesting. You just never know where good info might come from, even in the middle of a p-ing match, something interesting will sometimes come out. Not often, but sometimes.... Quote:
They seem like a hybrid "fast burn" chamber, having a better quench pad on one side, but not so much the other side. A "fast burn" chamber has a sort of 'dual quench pad' or kidney bean shaped chamber- which I suppose yours could also be said to have. In that just the quench pad(s) isn't all there is to a fast burn chamber, I might have been accurate to have just said "fast burn", period! ![]() GMPP FAST BURN CHAMBER |
I have the balancer marked, i have an aftermarket timing pointer, when the motor is at confirmed tdc, the line at my balancer lines up with the hole at tdc on my pointer. So, engine off, using a piston stop confirmed tdc, and everything lines up, start car, i have a snap on timing light, i set it at 38*, point at the tdc hole in my pointer and voila, clearly the line on my balancer is visable through tHE pointer at the tdc mark. Thus indicating 38* correct? Did i mention i hate timing? Oh and no vacuum advance, just 38, all the time... |
The motor will want 34 to 38deg timing at WOT to make max power.
More than what the motor wants will not make more power. The converter stall is very low. 3600-4000 is what you need. The XE284 in a 350 wants to rev. Take the wimp chip out of it. set the rev limiter at 6700rpm. Get some ET streets and some rear "Air Lift" air bags so you can use it. Then go to the track and try different amounts of timing and watch the Q mile MPH. The timing that gives the best MPH is the amount hat makes the most power. This big car could use easily 4.56's but definatly needs the high stall. A 9" is not too much for this car. "2600" is not even getting in the program. 3600++ with the xe284 You want to be able to launch the car high on the torque curve at or near peak torque rpm. |
There is no advantage in using more total timing than what's needed- even w/o detonation, the earlier the ignition, the more loss of power can occur from the pressure rising as the piston's still rising. It's finding that "sweet spot", where the pressure of combustion doesn't overcome the advantage in lighting off the mixture earlier. It's MY opinion that I'd rather leave a couple HP on the table for the added insurance against detonation. Running on the ragged edge of detonation will bite you when you least expect it- even a 'bad' tank of gas can cause it, and detonation isn't always heard, either. If you choose to use as much total as possible, be sure to keep an eye on the plugs for signs of "peppering" on the porcelain. This is an indication of detonation and if you DO notice it, back the timing down right then and there. That's not the only indication, but a bad one- that pepper is aluminum from the piston. The plugs may look overheated, the ground strap can get damaged and in real bad cases the porcelain will break. |
For those of you who don't understand why I don't just jump right on every combo where the OP asks for hp figures for their combo, here is one of the reasons. I need cylinder head flow like the figures I'm showing here, using the manufacturer's published flow, but factored down by 5% in an attempt to circumvent the BS and get down to brass tacks. This takes time. Lots of time. I have to go to the manufacturer's site, pick out the head you have, write down the flow numbers, put them into the calculator and multiply by .95, then enter all the data into the software. If you'll do it for me and publish the figures like I have done here, it makes running a DynoSim much easier for me.
Factored Patriot flow figures by 0.95, new figures are here.... 0.100 66 55 0.200 133 99 0.300 183 136 0.400 218 167 0.500 246 180 0.550 253 185 0.600 256 190 0.650 258 195 0.700 259 200 12-250-3 (XE284H), 423 hp @6000, 421 ft/lbs @4000&4500, 350 ft/lbs @2000, 178.8 BMEP @4000 12-246-3 (XE274H), 417 hp @6000, 435 ft/lbs @4000, 380 ft/lbs @2000, 184.4 BMEP @4000 12-242-2 (XE268H), 409 hp @5500, 440 ft/lbs @4000, 394 ft/lbs @2000, 186.2 BMEP @4000 12-212-2 (280H), 410 hp @5500, 430 ft/lbs @4000, 373 ft/lbs @2000, 182.3 BMEP @4000 Based on the results, for a street motor, I personally would choose the XE274H and give up 6 hp to pick up 30 ft/lbs of torque @2000. On this particular motor, a XE274H combined with a high-rise intake such as a RPM or Stealth would result in these figures... 460 hp @6000, 465 ft/lbs @4500, 371 ft/lbs @2000, 196.7 BMEP @4500. Notice the dramatic jump in Brake Mean Effective Pressure. The motor is working much harder now with the correct cam and manifold. Good, tight squish will be critical. |
| 350 Chevy, Head and Timing question. | monzter | Engine | 7 | 09-10-2009 06:52 AM |
| Best timing for Best HP zz4 | zz71s | Engine | 0 | 06-26-2008 04:42 PM |
| Timing question 69 vette 300 hp 350 ci | Bill Small | Introduce Yourself | 2 | 10-20-2007 05:05 PM |
| GM crate engine Timing Question | garretthes | Engine | 4 | 10-09-2007 05:12 AM |
| The 80 Hp Question | big455 | Engine | 8 | 07-22-2003 06:58 AM |
