Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing / Idle
Thread: Timing / Idle
Old 08-16-2011, 01:34 PM
cool rockin daddy's Avatar
cool rockin daddy cool rockin daddy is offline
1.21 giga-watts???!!!!
Sir, if you understand that you don't set the idle by changing the initial timing, you should understand that you don't change the timing by adjusting the idle! You have to adjust the idle speed screw to adjust the idle speed.
