timing at idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2005, 10:05 AM
Redman Racing
timing at idle
Hey everybody,
My question is about timing at idle. This is my setup-
Done-up Chevy 355 10 to 1
comp cams exreme energy 507 510 lift
240 244 @50 dur
AFR 195 heads 58cc cnc ported of course
Edelbroc RPM air gap manifold port matched
Done-up holley 750 tuned
85 0lds cutlass 442
200r4 that chirped with the old motor but I will smoke it soon probaly
3000 stall
3.73 stock open 8.5 no slicks for me
My problem is that I have the stock HEI that I freshend up and am replacing soon, but do not know what the timing should be at idle. I believe it is at 20 degrees initial at idle and 30 32 at 3000. The motor idles at around 900 out of gear and around 750 in gear.
The motor has about 2 miles on it plus the cam breakin so far (i just started it 2 weeks ago). I took it around the neighberhood and with just tapping the peddle I can tell its going to be little bit before I get used to the power.
I have gotten some ideas of horse power from the AFR dealer and compcams but I was wondering what you guys would give in?
Thank you for your time
Old 03-20-2005, 10:23 AM
what compression do you have, also is that 20 degrees initial timing and 32 total.
Old 03-20-2005, 10:36 AM
Redman Racing
i have 10. compression and yeah
Old 03-20-2005, 11:08 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
timing
Use total time at 36 deg. don't worry about static time. Idle should be lower. I set mine so the tranny doesn't load up.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
