Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing Issue
Thread: Timing Issue
Old 04-08-2012, 02:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
X2. Be sure the timing light's inductive pu isn't getting signals from the wrong wire, even if the pu is on #1. Use #6 plug wire if there's cramped quarters around #1.
Info HERE on the different timing tabs/damper lines that can also confuse the issue.
Be sure the outer ring of the damper hasn't slipped, more HERE on finding TDC.
